02 BMW 1150GS well sorted!!!
Hello Gents,
By the way, my name is Chris, divorced ya know, & I don’t need my X knowing my world.ED was gracious enough to accept my admission to your forum ))
I am in the middle planning stages of a 2+ month tour of your beautiful country, both North & south islands. I am planning Dec, Jan & possibly into Feb.
I have a 02 1150GS that I will need to sell upon completion of the trip, since as of this writing it is super expensive to ship it back (.
I may have a back up plan to get it out with one of the wineries my friend does business with, but I can’t be certain of that as of now.
So that catch is that I need a solid deal before I can ship the bike out, otherwise I will have issues with customs ((
Here are some details of the machine.. adorned in the fastest colors, of course 😉
2002 BMW 1150 GS
30,XXX miles
ABS NON servo
$4000 USD
Please contact me directly at k12pilot @ me . com
I gave this bike a METICULOUS & THOROUGH go through this winter for the trip & NEW OWNER
Everything I mean EVERYTHING HAS BEEN GONE THROUGH
If you can name it it has been done, I have pix of everything!!
I am SUPER NEUROTIC & OCD with all of my bikes (20) & especially so since I will be FAR away from HOME )
You will have to do NOTHING but change the oils for MANY miles to come ))
The bike has also been fully detailed for bio security entry )) OCD!!!
F&R Ohlins Shocks NEW last fall
Jessie side & top cases
Hidden Jessie tool box
Roto Fuel packs
PIAA lights
Nuvi 660 Nav unit with locking mount
UK headlight swap for driving on the wrong side of the road ))
Throttle lock cruise control
Touratech rock guard
Touratech rear fender extender
Touratech steering stop
Touratech hand deflectors
ROX Bar Risers
Zetechnic windshield with winglets
Aluminum tool tray cover
Adventure series front fender beak
PIAA AUX driving lights
All stainless steel brake & clutch lines
CSS tank protector set
Sargent rider seat
NEW
F&R Tires & valves Avon Trail riders at the moment I may put K60’s on it for the trip
Front wheel bearings & seal
Clutch disc with extended hub
Starter
HALL sensor
Final drive FULLY rebuilt All bearings & seals $1000 bill right here
Swing arm & FD pivot bearings
New brake pads F&R
AF-XIED Module
Abs module rebuilt works perfect
Alternator belt
Air filter
Plugs
Valve cover gaskets inner & outer
Fork oil & dust seals & fluid
QD fuel connectors
Fuel pump, pressure regulator, filter & hoses tank lining is perfect
Injectors serviced
Fork bridge & ball joint
Odyssey battery
Battery/starter jump lug
As of now… the only things pictured that will not be going with the bike are the shifter & the pegs as I am already looking for a bike to replace it with. Stock shifter & fastway pegs w lowering brackets will be included.
Seat bag not included, I need to get my gear home. Unless you have a suitcase for me ))
Service
All Splines checked & lubed. Perfect condition
Rebuilt clutch slave cylinder
Brake & clutch fluid flush
All electrical connections & contacts deoxed cleaned & greased
All grounds cleaned & greased
All wiring sorted from previous owner
Valve adjustments
Throttle bodies synced
I am sure I am missing some things…
Spare parts for the trip, just in case ((
Spare Injectors Fully serviced & tested
ECU module Tested on bike
Ignition switch & key Tested on bike
Hall effect sensor Tested
Emergency Injector hose repair kit
Gifts to the new owner
BMW Rally Pro 2 jacket Large
This jacket is a bit faded but still awesome & MANY miles left in it ))
There will also be a tank bag on the bike but I have not decided which one I wan’t to use for the trip.
Thank you & ride Safe
Chris
Geez thats some bike mate.
Are you entering NZ on a carnet or will you pay what charges the NZ customs ask, either way the bastards will want cash off you if you don’t get the bike home, things might have changed recently but please make sure.
PS if it was an hp2 I’d have been keen to buy it. Happy travels. H
